> Input Bias : 200na Typ. 800na Max.
Smoke some really good stuff so we can pretend the "typical" really is a likely number.
Assume the other input is just grounded.
200nA times a 2K resistor is 0.0004V= 0.4mV.
200nA times a 2.08K resistor is 0.000416V= 0.416mV.
0.400mV-0.416mV= 0.016mV drift as you move the pot.
Everything is 4 times worse for the 800nA worst-case. 1.6mV input offset voltage due to bias current and resistors; 0.064mV wobble as you fiddle the pot.
> Input Offset: 10na Typ. 150na Max.
The smoke wore off: numbers that represent cancellation of two numbers, like Offset Current, are never typical; bet on nearly worst-case. (Actually your design should always tolerate a worst-case chip without getting a Warranty Return or requiring you to sort-out marginal chips.)
First: take a wild round number and see if we are in trouble. If the chip in hand has 100nA offset current, then if we "match" DC resistances we will still have half the error due to the uncancelled 200nA bias current. Not a big improvement. True, a lot of chips will be less than 100nA, and maybe even dead-nuts-zero (at specific temperature and moon-phase), but could be 150nA too.
> Offset voltage is: 0.5mv Typ, 4mv Max.
So for ~2K resistances, all this current-error is small compared to the voltage error. If milliVolt errors bug you, you are going to have to trim the offset voltage, and in the process you can also semi-trim the offset current errors. If you are building DC-accurate amplifiers for analog computing, or thermocouple or strain-gauge meters, you have to do that (or buy spiffier chips). For most musical applications, small DC is not a big problem, and big DC can be blocked with a cap.
Remember that until this op-amp concept invaded audio, all our stuff had 6V to 200V output DC offset, and we didn't know there was a problem with that. Low offset +/- power amplifiers can give some circuit simplification, but don't let it go to your head.
