MNA
Member
I am putting together a shopping list for my Green Pre project. I found some cheap stereo 1/4" jacks to use as outputs, and then I realized that these jacks are not isolated from the chassis (no isolation between the sleeve and the chassis). I guess that means that there is no way to star ground the outputs? Does that matter? I realize that there is no absolute answer to this, except maybe "try it, and you'll find out", but if I rephrase the question: would you order isolated or non-isolated 1/4" output jacks? (the isolated ones cost four times as much, that's why this is even an issue)
/martin.
/martin.
