finbase
Hi folks!
I'm going to build two gssl units, one "regular" (since I'm still a n00b I want to do that first...) and one with input and output transformers, for "colour".
I've done a lot of search in this forum, and I've found a couple very interesting mods for both inputs and outputs. Nevertheless, the projects I'm talking about are different, so I'm still a bit hesitant...
The input section would derive from the Jensen mod schematic I found, but the actual transformer would be Cinemag CMLI-15/15B (interchangeable with the JT-11P-1). The output section would derive from the mod I found from Luny Tune's passive EQ + GSSL thread. The transformer I'm going to use for the output is CMOQ-2S.
Please see the attached pictures for more detailed "insight" into the modifications. (Output mod attached to the following message.)
The question is: If I do the described modifications in the both ends of the GSSL schematic and use the CMLI-15/15B and CMOQ-2S transformers, will the unit perform properly? Or should I be aware of some further problems?
finbase
finbase
