Guitar Splitter - Pete Cornish Style
CJ
GDIY Supporter
California
threw this thing together,
Cornish buffer, true bypass,
amazing that it is hard to tell when it is on, does seem a bit more musical when engaged,
i want to drive two amps, or a parallel effects chain if using one amp,
might have to add some gnd lif switches,
wound a Neve style xfmr, 1: 1 + 1 to isolate the outs but it lacked bass so i ditched it,
sanded down an old aion fx board that i did not like and used the foot sw board as is,
seen those "greenies"?
that's where the funk lives.
i don't even want to hear about panasonic.
Did you do the case labeling with a silver sharpie? It reminds me of the ones that I do that way......................only your labeling is neater than mine.
What voltage is needed to run this?
Also note that some amps can use a patch cord to drive both channels, if you have extra jacks...
Tx!
CJ
Put the circuit in LT spice make sure to add a pickup tone and volume sim and reduce the C2 value in steps. You can get a bottom bump.
I tried the buffer out last night with two àmps, a vibro champ and Princeton reverb. The neat thing about the foot switch is you can get an immediate comparison between buffer and no buffer. With no buffer you get a drop in level and some muddiness. With the buffer it sounds the same in both amps as it does with one.
I used a mic in Neve,
only about 8 Henry's so maybe I need a bigger core to fix the bass drop. It was 499 turns of 36 awg pri and bi fi secondary of 499 t each. There are two coils, the winds were put in series.
Thanks Gus I will give that a try!
I did not get any ground loop hum with the buffer so maybe I do not need the transformer. I ran a freq plot on the buffer and it is flat til 83 k Hz where there is a pretty good bump. Maybe that is why there seems to be a tiny bit more presence with the buffer engaged.
The first device like that which I built might have been a 5534 buffer into a V74 input transformer (probably nearly 30 years ago). It did sound great as in 'pretty much inaudible', but he transformer became unreliable. Later I tried other manufacturers, but I didn't like the sound. Finally I realized that multing into 2 amps actually works well with a passive plug box, I never had a ground loop. Good guitar cables help of course. That's in my studio, on stage I'd be more concerned. As simple as possible :)
Michael
