ComodoComplex
I've rewired up my PSU after years of loving my G7 build, but am now facing an issue. The power supply rail is supposed to get up to 160V, but is instead only at 56.7 V. The reason, I presume, is the neon indicator lamp that I've wired in series with the power switch. I assumed that the lamp would essentially act as a short, but it seems to be lowering the available voltage through the transformers. Is this correct? I can't quite get in and measure the voltage across it because I heat shrinked everything so nicely ![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Unfortunately there isn't a lot of reading on the internet about this, so I appreciate the community's insight here! How do you properly use neon lamps without lowering the voltage? Or is my problem elsewhere? Wall power measures 120VAC fine.
