The G7 needs some 6V for the heater and some 120-160V for the tube and polarisation. If you want to use this supply unit, you'd need to rebuild it to get the right voltages (and for that you'll probably need the schematics). Also, you'll need to add a switch for the polarisation pattern to the box - and use a 7-pin connector to go to the mic.
...Probably easier to build a new supply....
Jakob E.
