Been working out some values for Gyrator circuits to build up some EQ sections. The Gyrators are to be used in a single buffer eq, as seen on the Forsell tech. website. The configuration has the gyrators acting as freq. dependant input attenuators (for cut) and freq. dependant ground shunt in the feedback network (for boost). I'm hoping that this topology is common enough for folks to know what I'm on about...
I found some other formulas for the same gyrator circuits, and played with them along with forsells basic formulae. It wasn't to simple at first to get desirable figures, as the gyrators must use same R value for every band to keep boost/cut constant. This made picking caps tricky...I came up with the following method for picking my values. (bearing in mind easy component choice is more important to me here than precision of Q or Fo)
I took this formula.. 1/ (4x C1 x Q x Pi x Fo)=R
As R is fixed I rearrange for this.. 1/ (4 x R x Q x Pi x Fo)=C1
I put in my target Q and Fo to get C1,
e.g. 1/ (4 x 3k x 2 x Pi x 33)= 0.4uF
I then make C1 the closest available value, 0.39uF, and substitute it back into the formula to find the adjusted Q...
e.g. 1/ 4 x 3k x 0.39uF x Pi x 33=2.061058.....=Q
I then use this formula to find C2.... C2=4 x Qsqrd x C1= 6.626uF
Then put C1 and C2 into this formula to get my final Fo....
Fo= 1/ (2 x Pi x R x Sq.Rt (C1 x C2)) = 32.577...
Finally I put my final C1, C2 and Fo values back to the original formula to find Q... In this case 2.0878....
My question is...Am i on the right track? I know this seems long winded but it lets me use available C values. My main concern was that the ratio of C1 and C2 I end up with is not the same as the original found values. But I've run the final figures through every formula and the math works.. even using a different formula for Q...
Q= 1/2 x Sq.Rt (C2/C1)
Also, anyone have any info on general guidelines for this configuration... min/max R/C values or anything like that would be useful. A good search came upwith only the info to get as far as this so some confirmation would be handy.
