Soldering direct to the pad is a good idea and you don't need to anchor. However in my experience of soldering SMD's is it a pain they are not designed to be hand soldered. They like to stick to the iron. I would still use a tiny dab of super glue to save my frustration and time chasing a tiny little SMD around. Otherwise you need 3 hands, one to hold the iron, one to hold the tweezers to keep the SMD in place and one to feed a tiny bit of solder. Yes you can tin the component and pad then solder without any reflow, but this can create a dry or weak joint. When holding such a small component with tweezers there is risk of movement post heat which is more likely to create a dry joint. If the SMD can not move the risk is removed.
My point is it will probably make the OP's life easier if you fix it in position before soldering and the likely hood of a dry joint will be less. You could use something less permanent like Blue Tac. Or they might be a solder ninja and this is not required.
