pucho812
Trying to figure this fault out. Got a unit on the bench that is 8 channels of eq. Line level in and out at +4dbu via that balancing chips. Running audio through the unit the level is +4 on every channel in bypass. If I turn in the eq and leave it flat, level is still +4. This is all normal operation.
So here is the fault one channel out of 8 drops level by about 1.5 db when the eq is inserted as described above(with the eq flat) , I have gone over everything and all parts are the same per channel. All the chips are the same and all parts are the same. All things seem to test out the same.
I am out of ideas. About the only thing I haven't done is swap the 10uf bp input caps the are in series with each leg of the balanced input going in right before the balancing chip as well as swap the balancing chip input. Hmmmm...
