Help identify this type of capacitor-Need Upgrading?
craigmorris74
GDIY Supporter
benton, ky
Below is a picture of an EQ that I'm considering for use in my mixing setup.  I was wondering what type of capacitors these were (film, ceramic?).  They aren't marked with any brand name.  If they were ceramic I probably will change them for some nice film caps.  Sorry the pic is so blurry.
    207.9 KB
If your're talking about the large yellow ones, they're probably polyester... and they're probably just fine... I wouldn't touch em
If it's the little yellow ones... ceramics... but they're sitting off of some opamps, so probably feedback caps, leave em.
cheers,
dave
The little yellow ones may also be tantalums - in that case they should have a little polarity sign - often a "+".
The black round one is of course an electrolytic.
Sorry, was the rectangular yellow ones I was concerned with.  Polyester will be fine, just wanted some film type there.  The high band has two ceramics, and those will have to go.
Thanks for the help,
Craig
Yep - big box yellows are polyester film - unless the unit has been abused these should still be good.
Little yellows look like X7R or Poorer Z5U multilayer ceramics - often see these as feedback caps across output and -ve input of opamps - they`re to tame hf oscillation. What`s the opamps - dual? They look adjacent to middle 2 pins - test with continuity meter - i,m guessing across pins 6 and 7. Opamps often have 100n X7R`s to decouple the supply rails - pin 4 to 0v and pin 8 to 0v if it`s a dual opamp.
