altfidelity
Hey everyone,
I'm looking to tweak the compression ratio in the D&R FET limiter and could use some guidance. Would really appreciate any help offered. If I'm getting the circuit right, would adding an extra dual-pot next to the R60 and R30 resistor to ground do the trick?
Also, I've been curious - is it possible that this sidechain is in a feed-forward configuration? Normally, FET circuits tend to be feed-back right?
Thanks in advance for any insights or advice you can share!
