Help with 1176LN H Funky FET? (Q1)
jwhmca
USA
Trying to calibrate this guy.... suspecting Q1 as a probelm...
Symptoms include:
1. Huge change over warm up cycle.
2. Jumpy output and GR levels.
3. 20 ratio = nothing, then switch off and back on... then it works.
4. Intermittent operational all over the place.
Basically, the thing is wompess, and I can't really get it to settle down and be repeatable. I have already done a recap.
Do the FETs fail?
When they do is it always hard short or open? Or do they go crazy?
Sounds to me like bad contacts. Connectors, solder joints, switches, pots.
JFET seems pretty unlikely.
DC voltages readings could give clues. If the +13V (say) rail goes 6V or 17V when you smack or switch things, hmmm. Measure at the power supply but also out in the circuit.
