Help with finding replacement for voltage "Dropper Type"
hoyahelper
Member
Hey all,
I've attached a datasheet for what seems to me like a 5 pin voltage regulator - with 5v output - i can't get this specific one anymore but am assuming theres gonna be a modern replacement but i haven't had much experience in this field and was wondering if someone could guide me!
Thank you lots!
  • STR9000.PDF
How about a 7805 (and bend the pins if necessary)?
What's the voltage going into this? (To determine whether it really needs to be a low-dropout regulator or not)
Can you get 7805s in 5 pin configurations? Voltage in is 25v so it could be possible?
Why 5 pins? 7805's should take up to 35v in; any idea what sort of current it would need to provide?
its 5v out - actually 15v in so no issue there - current is 2a out
extra 2 pins are shown in use on this schematic - pretty sure they are essential right?
its the str9005
You need to check the power dissipation that the regulator you're going to use, has. If you're dropping 15 volts in to 5 volts out at 2 amps, that is a 20watt dissipation that the regulator has to dissipate.
The LM323 will do the job but it costs $67 at mouser, you used to get them for $1 as new surplus!
Another regulator that would work is the LM338 which is good for 5 amps but it is adjustable output so you will have to set the output voltage. Either way, you're going to need a large heatsink to dissipate that kind of power from the voltage drop the regulator has to do.
