Matt C
I'm looking for some advice in tracking down some noise in a power supply I'm building on stripboard. So far it's a real mystery to me. It's a run of the mill bi-polar supply with both +-15Vdc and +-12Vdc. I'm getting noise on the outputs that is leaking into the audio circuits and becoming audible. Here are some details:
- I've been measuring on a scope with the ground wire connected to the chassis safety ground bolt, and with this arrangement I can see the noise on all the PSU outputs AND ground at the output. So it seems like ground is somehow being contaminated in the PSU circuit
- noise is 120Hz
- gets more severe with more current, but still present with only the voltage regulator's idle current and nothing else connected
- changed slightly but still present when I used a different power transformer
- present when using both 78** regulators and LM317 adjustable regulators
- did not change after putting in fresh regulators, new (faster) rectifier diodes, and new (bigger) filter caps
- no change after connecting and disconnecting the PT's static shield lead to chassis
- no change after connecting and disconnecting PSU circuit common to chassis ground
- no change after rebuilding the circuit on a new circuit board
- no change when connecting only +-15V or only +-12V
- when looking at the rectifier output/regulator input, I see the usual small, sort of triangular wave of ripple, but there are what look like extra quick dips and peaks at the corners that seems to maybe correspond to this noise. Tough to explain the shape properly, and I can't get a very stable image on my scope to take a picture for you.
alright, if anyone has any idea what could be causing this weird ground noise, please let me know. I'd love to finally get this thing working! Thanks for the help!
- noise is 120Hz
