Hi all,
I had a couple of questions about an off the shelf power supply I'm using - hopefully someone can help me out..
I picked https://quasarelectronics.co.uk/Item/velleman-k8042-symmetric-1a-power-supply-kit up to get some op amps happening in a little project I'm working on.
Off it I'm powering the following: 10x ne5532 (which from the datasheet can draw a maximum of 10mA per rail?), 6x SSM2019 (8.5mA each) 1x THAT4301 (18mA), 2x AD825 (I think only 6.5mA per rail, although I'm unclear on this), and 1x TPA6120, which I'm using as a headphone amp - I don't entirely understand how much current this draws either!
Anyways, I figured the lot had to be under 200mA, so I bought the above +-1A supply. And if I measure this circuit connected up but with no audio running through, it draws around 150mA per rail (assuming I can read a multi-meter, which isn't a given!) at +/-15V.
The supply, however, gets a bit of a smell on! After a minute or so of the supply being on I can squeeze a heatsink for no more than a second or so - I've no idea if this is normal or not? I haven't run it for long enough to see how hot it gets - I'd rather know if this is right! So I looked up a few things, and I'd love to know if what I think I've worked out is correct.
The output of my toroid is 21VAC on each of the secondary windings (that's another question - it should be 18VAC - why is it high?), so can I calculate 21V(input voltage), minus 15V(supply output voltage) multiplied by 0.15W(circuit current draw) to get 0.9W of heat to be dissipated by the heatsink? I'm using two of these little guys https://quasarelectronics.co.uk/Item/to220-heatsink-pre-drilled-19mm-black which I see have "21°C/W thermal resistance" - does this mean its temperature rises by 21°C for every Watt it dissipates? And would you say it's a big enough sink for this project? I'd have imagined for anything under a Watt, anything remotely heatsink shaped would have done... Which makes me question the heat and smell, and whether the amount of power the regulators are dissipating is far more than I realise. Or is it just new component smell!?
Finally, and a separate question, can I run two separate power supplies off one secondary winding? ie, if for example I bought a second identical supply, could I run the toroid into both of them? Or is there a reason I see every power supply having a single diode bridge before splitting off to multiple supplies (other than cost, obviously!)?
Many thanks for any help you can provide!
C
C
