salomonander
- Joined
- Aug 28, 2011
- Messages
- 951
hey
i need help with designing a mic pad for some preamps that dont have volume control.
all my mics have 200Ohm output impedance. the preamps are 2k. so thats all fine. from my research i gathered that i should use a u-pad.
i also have lots of 4pole 5position rotary switches to burn. i need help with finding the values and getting the wiring right though.
i couldn't find a u-pad calculator anywhere. so i assume i have to use an l-pad calculator? but how will the values translate to the u-pad.?
will i have to switch all resistors in order to get the impedance and attenuation right? or is there a smart way to use less resistors/poles? im asking this since on a commercially bought rack i have (using the same amps: v72) there are some resistors on the xlr inputs while the rotary switch only has one pole... so only one resistor gets changed.... im wondering if this is a compromise or some clever engineering i dont understand
thanks alot
thanks alot
