Soundguy makes a damn good point there; it's definitely a good idea to start on a low voltage project. (Although, technically, it's the current that kills you!) It only takes 1/4 of an amp to stop your heart, so, actually, anything with a AA battery, the right amount of resistance, and a few margaritas could theoretically end you. (A bolt of lightning is like @ 20,000 amps, just for perspective.) I was reminded of all of this today at work, when I was repairing a switch, and came in contact accidentally with the hot 240! (The circuit couldn't be de-energized, so there ya go!) :idea:
But, still, tube stuff with the lethal voltage is definitely something you have to give total respect to, which means proper handling (discharging filter caps, isolation transformer, etc.,)
The first audio thing I ever did, was a little guitar preamp with a 741!
Yeah, it's funny to me, too, to look back on it now! But, that's how you learn, by doing! It also did NOT work right the first time I had it on; actually, it was intermittent. It probably only had about 10 parts to it, so it was definitely easy to build.
And, as soundguy points out, room eq, used properly, is better than any electronic device! :sam:
