I had to print it and assemble it in order to make it legible. So far, I see that the signal is delayed, probably in order to apply some predictive compensation, the cross-over has a gentle slope of less than 6dB/octave and the detector has a perfect 12dB/oct slope which precisely matches acceleration, so overall, it's an interesting combo of wide-band and split mode.Gold said:The print is a four page fold out IIRC. The inductors are a separate PCB that forms the other side of the module. It may be a separate print.
Using analog multipliers as gain cells, it is perfectly suited for feed_forward topology.
It's the culmination of analog art, before digital audio wiped the slate clean.
