k brown
I know there's not a whole lot of interest 'round these parts in SDC omnis (this is kind of a multi-pattern LDC playground), but I thought I'd share my discovery of these beautifully-made mini capsules from inside an Audio Technica AT841R boundary mic.
Separated from their stock power modules with tiny tunes transformers, and hooked up to a quality transformerless circuit, these sound amazingly good; and shockingly quiet for such a teeny thing: 7.5mm outside diameter, with a built-in 2SK660 FET (and NOT SMD) and RF caps. With the top tamed about 3dB, these hold up extremely well against my Sound Room cherry-picked Oktava MC012 omnis.
The later iteration of these (in the U841R) have just a simple, small hole in front of the diaphragm, instead of these precision-machined slots. Body is not stamped aluminum, but machined brass. The actual capsule unscrews from the tiny back-end that holds the little PCB with the FET on it.
Though the published response curves are quite similar, they sound way less bright than my Shure Microflex omnis (which I've never been able to find a use for, except inside really dull pianos).
The top end is less hot hooked up to an 8533 power module, compared to it's stock module; maybe a boost circuit in it?
