earthsled
Hi all.
I'd like to add a HPF to a neve-like 1272 / 1290 preamp similar to this: http://www.jlmaudio.com/JLM1272hotrodmod.pdf. I understand that it's possible to simply add a small value cap between the input and output sections of the BA283 board (between pins P and L).
My questions are: What value cap should I use? Is there a way to calculate for an 80Hz cutoff vs. 100Hz? Also, does the 5.6K resistor (in the JLM circuit) need to change value for the HPF?
Thanks in advance for you help!
