High Pass Filter Racks
naths101
Member
Sydney, Australia
Thought I'd throw out an idea for someone to make a rack of high pass filter clones in a 12 or 16 channel configuration similar to the API 215.
It comes from needing such a product for tracking with pres/eq & mixing on consoles where there is little or no filtering. Additionally a low pass filter would be great too.
How easy would it be to build such a thing? When it comes to DIY I'm a beginner and not quite in a position to build it myself at this time...
nath
I guess it depends on what kind of features you wanted your HPF to have - can you elaborate?
What cutoff slope would you want?  6dB/oct, 12dB/oct, 24dB/oct?
Did you need a single fixed frequency HPF, or perhaps a stepped rotary switch per channel, or continuously variable frequency?
Do you have a particular filter topology that you like, or did you need some advice on what the options are?
shabtek said:
i believe gustav has some boards for a 2 band hi/lo filter in 500 format
Gustav has the Studer 169 eq if that's what you're talking about? It's a Hi and Low shelf with a mid freq presense.
I'd be after at least a 12dB/oct for HPF and 6dB/oct for LPF.
If it was a switchable 6/12dB that would be even better, obviously.
How possible would it be for a variable frequency? Otherwise a stepped rotary would have to do.
I do have a module in the works. The switchable HPF and LPF will be 71 series Grayhill's, 5 frequency points per. Both are passive and switchable between 6dB and 12dB. The main purpose for this 500 series module is not for the filters. They are really an add-on bonus to what else is there. If you know me, you can guess what the circuit is based on. ;D :eek:
Best, Jeff
for making this filter unit can be used:
- a sbalancer input (active)
- an buffer for the HPF filter (12db)
- a balancer output used for the LPF filter (6dB)
the circuit could be made with:
- an IC opamp or DOA for the input sbalancer
- a discrete buffer or an IC buffer
- a balancer output, made with a DOA or an IC balancer or with two IC opamps.
since the circuit is simple could be made with discrete topology, even if a IC opamp can be used for input.
Best, Jeff
yes, the passive way is the best choise in this case
Best, Jeff
I have many customers that use Jeff's mic pres and they're very happy with them, just my two cents.
