Is anyone familiar with this unit ?
mid 60's vintage ,previously owned by Noel Reading , theres even a chance Jimi himself graced its keys at some point .
Initially I found the fuse holder/volts selector was bad , I replaced that with an IEC mains socket with 110/240 voltage selector ,
now it powers up ok . Upper few octaves of the keyboard sound ok ,but tuning is suspect . Lowest portion of the keyboard only puts out a hum when the keys are pressed , next section up puts out a glitchy out of tune wonky sound . Vibrato seems to be doing what it should with the various buttons functioning as they should . Theres a knee opperated lever underneath which should control the vibe intensity ,but instead seems to function like a swell or volume pedal.
There is a manual online at 'Manualslib' and 'Electrotanya' but for some reason I couldnt download it . Schematic is there too , very simple box of tricks , full of megohm value resistors ,that no doubt have drifted well out of spec over the 55 years or so .
link to schematic here :
https://www.manualslib.com/manual/904265/Hohner-Symphonic-30-N.html?page=9#manual
Hopefully someone has renovated this or a similar unit and can advise me where to start or if its a viable job .
