Electrobumps
Hot Springs Reverb - Modification Ideas
I love spring reverb, but I don’t love the noise issues and mechanical spring noise you can get with transients. I own the Urban 111B and Great British Spring which I use pretty regularly on projects. I have been looking at the hot springs project for a while and from the few builders’ reports, they say it sounds great.
This is how I would like to upgrade the circuit.
These are the tanks originally recommended for the build.
1FB2B1D - Accutronics
1 -2 Springs short tanks
2 - i/p 1475 Ω
3 - 2250 Ω
4 - Decay Medium
5 - I/p grounded o/p Insulated
6- Non Locking
7 - Vertical connectors down
8EB2C1B - Mod
1 - 2 Springs short tanks
2 - i/p 600 Ω
3 - o/p 2250 Ω
4 - Decay Medium
5 - o/p Insulated, i/p grounded
6 - Non Locking
7 - Open side down
I do not have the know-how to create schematics and Gerber files. This is not something I have time to learn at this point in time. It would be great to collaborate on this build with someone who has or wants to learn those skills.
I have attached the original build article and some spring info.
- Change to balanced line level to +4dbu i/o
- Change the quad op-amp and upgrade to 2 lower noise and faster dual op amps
- The grounding scheme is questionable and shielded cable should only be needed for reverb tanks in an upgraded version
- Build smoothing onto the board and use a good-quality wall transformer for DC
- Make the PCB a stereo unit instead of Mono
2 - i/p 1475 Ω
3 - 2250 Ω
4 - Decay Medium
6- Non Locking
8EB2C1B - Mod
2 - i/p 600 Ω
3 - o/p 2250 Ω
4 - Decay Medium
6 - Non Locking
7 - Open side down
