Yes, the first thing i've done it's been swap woofer, amplifier and even cables... nothing worked :-\pucho812 said:have you tried swapping the woofer to see if the problem goes with the suspect woofer?
You need to keep the load. Open-circuit x-over is just insane.Nickos said:i need to keep the load or can i disconnect the speakers?
