Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Normal
No pivoted arm replicates the cutter lathe which goes straight across the disk. The longer has a larger radius arc, a little closer to a straight line, so cartridge angle error will be less. It will also have more mass which has its pluses and minuses. If you use a quality cartridge you want a good TT. This doesn't sound like a hi budget project (but I could be wrong) so good enough may be good enough.
