Good to know and thanks! I have so many fw interfaces (getting to be obsolete). I've never had a chip fail yet. But I realize it will eventually happen!Diode test mode on your meter CAN help - red probe on ground, black probe on each of the four data pins (if any show near zero, that port is dead); black probe on the Firewire chip's 3.3v rail, red probe on each of the four data pins (ditto). Normal readings should be around a diode's forward voltage drop (0.5-0.7v).
