Hum with electric guitar and bass in Breadboard JFET (single gain stage)
777funk
I'm getting some great sounding tones out of a basic JFET gain stage (similar wiring to a 12ax7 common cathode Fender type setup) similar to the Till Preamp. When I roll the volume down on an electric guitar or bass, it goes away but with the volume up, it's unusable.
Where do I look? One thing I noticed is that in the Till amp the input from the shielded cable goes direct to the FET gate. I put a 56k resistor in series (like you'd see in a Fender amp) and this helped. Anything else I can do?
I have basically a star ground on the breadboard (all grounds in one series of holes).
The hum goes away with the guitar volume down (shorting the input) and the power supply is a 9V battery.
SOLVED: I put the circuit inside an enclosure and everything is good now.
I built it on a breadboard and a perfboard and both examples were very noisy with interference. I put it in an Altoids tin and quiet as a mouse.
Enjoy the silence :)
Well done.
It still amazes me what a 9V and a few transistors can do for and to, a guitar or bass.
Hum absolutely kills me, so I use active and noise reducing pickups where possible.
It's incredible how quiet emg pups are compared to stock.
But yes, a nice enclosure can make a big difference.
