bobschwenkler
These boards are now available for folks who want to buy them.
www.bicyclerecordings.com/312
I've been working on a design for a 312 type preamp circuit board. I got most of the parts in and fired it up today. Works perfectly!
I built the board to accept standard 312 inputs, LL1538, and Jensen JT16A.
Outputs are servo or standard API transformer outs.
DC bias option for the +/- inputs.
Pad and polarity reversal on relay switches and +48V for phantom of course.
There'll be a Grayhill 12P on it when it's done.
I designed it to fit the Neutrik PCB mount XLR connectors and included mechanical brackets on the front and back; these boards will need no other mounting than to attach them to the front and back panels, similar to the 7th Circle models. Next project is to design the panel layout...
Tested with a JT16A, PTownkid 990 amp, and servo out. Compared to a Fabio 312 with CM-75101, 2520, and AP2623 out.
The API had a really cool character, but the detail and high end response in the 990 model was a big step up! Frequency response of the 990 model with my limited methods of testing seemed flat +.3dB from 10 to 20k, and noticeably more smooth than the 312's. At first I thought the frequency response must be exaggerated in the high end on the 990 model because I was hearing so much more there, but it seems to be a matter of detail rather than frequency response.
Below are a couple photos of the test jig.
In the end I'll be building an 8 channel unit. 2 ch. with JT16As and servos, 2 LL1528 and servos, 4 API style, all with 990 amps.
Once I have that all done and tested out, and assuming some marginal to moderate amount of interest, I'd love to sell some of these boards to people!
