matta
Hi Guys,
I am thinking about taking the plunge and getting a patchbay. For years I?ve
managed to get by without one as my system didn?t dictate the need for one
(I had a digital console that fed the ADAT of my soundcard and I didn?t use
any outboard gear) but with my DIY stacking up it is soon going to become a
nightmare to interface everything and patchbay seem like the logical
step/solution.
The bay in question I am looking at is the Neutrik NYS-SPP-L Bay, which is
has 48 1/4? balanced jacks divided into 2 rows.
From the research I?ve in the search done it seems the convention is to have
your outputs above your inputs on the bay.
I have decided to go for a balanced bay as 80-90% of my gear will have
balanced +4db outputs, but there will be the occasional piece of gear that
will have unbalanced prosumer gear that will be ?10db that needs to get
patched into the bay and then into the input on my soundcard (which is now a
Digi002R)
I guess my main question is now to wire in gear on 1/4? balanced jacks that
is not balanced? Should I wire them all as balanced even if they are
unbalanced? I don?t plan to run phantom through the bay at all if that is
concern.
Through my search it seems as if this should not be a problem as the cable
run will be less than 2-3 meters, but I?m just not sure how to wire it all
up.
I found a post that linked to a balancing box that Kev designed, but I don?
know if I need to go to that extreme if the cable run will be as short as I
indicated it will.
Any help would be much appreciated.
Matt
step/solution.
Digi002R)
concern.
up.
indicated it will.
Matt
