Majestic12
I just wanted to share something with you that I have designed for an upcoming monitor / control room controller project. It's a relay based, passive attenuator with 6 bit resolution to attenuate the signal down to -63dB. Also included are dim and mute functions. The board is controlled over i2c, so it can also easily used with an Arduino board for example. You just send one byte over the bus that equals the amount of gain you need and the relais will switch the corresponding resistors in the audio path.
Unfortunately, my layout software had the power pins of the PCF8574 port expander reversed, so some wire fixing was neccessary in this prototype...
