IC in the SSL autofade circuit??
quadwould
London
So on the file: http://www.gyraf.dk/gy_pd/ssl/ssl_82e27.gif there seems to be an IC that is refered to as "351" but i have searched high and low, but have not found anything on it. i found a part that was cross referenced to an LM351, but that was all........ at least on the major distributors...
looking further i found that the LF351 is a 8pin DIP. but the IC on the Audfade circuit : http://www.nrgrecording.de/autofade.pdf is a 14pin dip.
so i first thought TL074.. but that is probably not what is needed.... but i then thought that maybe i should check into the quad vesion of the LF351/ LF356.... and founf the LF444ACN or LF444CN. seems to fit.. but my qustion leis here.
are there any others that i should be looking at?? better specs?
and anyone know which diodes this thing needs... does the schematic say "1544" on 5 of them ?? and the 10V ones.. well suppose i have to look into which would work..
[quote author="quadwould"]so i first thought TL074.. but that is probably not what is needed.... but i then thought that maybe i should check into the quad vesion of the LF351/ LF356.... and founf the LF444ACN or LF444CN. seems to fit.. [/quote]
FYI - the quad version of LF353 is the LF347. The dual is called LF353.
the footprint... do you mean the Physical size of the area it takes up, or the way a quad op-amp works.. sounds like the latter....
the LF444 from National Semi seems to have that exact foorprint
so i am just wondering if there is something better than an LF444A or does it not really matter....
[quote author="quadwould"]the footprint... do you mean the Physical size of the area it takes up, or the way a quad op-amp works.. sounds like the latter....
so i am just wondering if there is something better than an LF444A or does it not really matter....[/quote]
I mean in terms of the pinout/functionality---it doesn't make sense. I doubt that the desired part is a quad op amp.
[quote author="quadwould"].... but the IC on the Audfade circuit : http://www.nrgrecording.de/autofade.pdf is a 14pin dip.[/quote]
It substitutes T4, T5 and T41 on the SSL schematic. LF347 is a good choice.
Footprint is OK.
... does the schematic say "1544" on 5 of them ??.. .
1S44, IMO (rectifier Si, 500V, 0.7A).
Regards,
Milan
So you thing a TL074 (LF347) will do. Ok.
well therre is already one in the comp itself. simple enough... just purchase 2 then..
1s44?? will look into that
1s44....[/quote]
I checked the SSL service manual. It is 1S44.
Anyway, any DUS will do the job, IMO. (1N4148, for example)
Regards,
Milan
