I see that on most application designs, the control input of the 2180 is being driven from the output of an op amp.
I was wondering if the control input could be driven from a higher source impedance, like a resistor divider, such as 10K/and a 1K pot, which would be the attenuator for compression ratio.
I looked on the datasheet, but found nothing about source impedance etc.
