> information on wire length and impedance?
JR gave you a simple resistance chart.
PentodePress has resistance, inductance, and reactance:
http://pentodepress.com/calculator/wire-inductance.html
Watch your decimal-points. (I would argue that "milliOhm" is meaningless in most causal audio, bump the dot over three.) (And micro-Ohms? Angels dancing on pins!)
> I know that the gauge of the wire does little to affect the impedance.
How so?
Line Impedance has almost nothing to do with wire, for short wires such as "we" usually use.
333 feet of #22 cable is 5.4 ohms one wire, 10.8 ohms round-trip. Put 600.0R on the far end, the DC/LF impedance is 611 ohms, which "is" 600 for any practical purpose. At 20KHz the inductance is about 64 more ohms... that may start to matter. If the source is zero-impedance, the "600.0" load gets 600/(600+11)= 0.98 at LF, 0.90 at 20KHz, -0.7dB roll-off. Going to #10 is better, but not near the change of cost. And 333 feet of typical "cable" shows ~~10,000pFd capacitance, so our source has to be under 50 ohms or we will get another 1dB droop.
As we go past hundreds of feet, we get fairly constrained in "good" impedance. That's why very-long audio systems favor 150 ohms: cable-pairs always zone-in around 90-140R. (500/600R comes from pre-Cable wide-pairs on glass insulators, which was obsolete before electronics became common; 600R still worked fine on cable past 1,000'.) Coax runs half that: hence all the 50 and 75 ohm RF coax. Wide-space pair may reach double: 300-ohm TV twinlead.
But few of us need to run Long Lines, and if we do we should have a box to tweak the top octave, cuz that's a lot cheaper than over-kill cables.
30 foot runs around the studio, terminated in "10K", ARE 10K, whether the wire-loss is 5 ohm or 0.2 ohms. The actual loss is under 0.1dB. The few-ohm parasitics are as dust upon the rock.
Small-stuff wiring is mostly about mechanical strength. #22 can be broken by hand, we like fatter stuff in rough studio/stage work, and the added copper-cost is offset by fewer breakdowns.
Speaker runs, it matters. 30 feet of #22 into 8 ohms loses 10% of costly power, and may show 1dB mis-damping since speakers are never perfect 8 ohms. Even 30' #10 won't be ruler-flat to 20KHz in an 8 ohm resistor (though speakers being wonky resistors, and never as flat as a half-good line, it works fine).
