drjet
Active member
Hi there,
3 month ago I build my Pultec MB-1 clone, which I use and like a lot.
Have a look right here:
http://groupdiy.com/index.php?topic=59296.0
But using the instrument input with my bassguitar gives me a very hot output even at lowest gain setting, which clips my audiointerface line input (Focusrite Sarlett 18i6). Because I really like this slightly saturated sound I decided to implement an output pad. I think three steps (0, -6, -12 dB) are enough, so I opted for a 3P4T rotary switch. I calculated the U-Pads as described on this page:
http://www.uneeda-audio.com/pads/
This is the way I calculated for about 6 dB output pad:
I wanted to have a series resistor of about 10k,
K-factor( for-6dB)=10´`(6dB/20)=1,9953
series-resistor(R1): 10k2 (2x5k1)
shunt-resistor (R2)= R1/(K-1)=10200/(1,9953-1)= 10047Ohm; I choose R2=10k Resistor
K-factor=(R1/R2)+1 => K=(10200/10000)+1=2,02
pad= 20*log(K) => pad=20*log(2,02)= 20* 0,3054=6,1 dB
for aprox. 12 dB output pad:
K-factor( for-12dB)=10´`(12dB/20)=3,9811
shunt-resistor (R2)= R1/(K-1)=10200/(3,9811-1)= 3421Ohm; I choose R2=3k3 Resistor
K-factor=(R1/R2)+1 => K=(10200/3300)+1=4,0909
pad= 20*log(K) => pad= 20* 0,6118=12,2 dB
Did I do it the right way?
I also calculated a three-step input-pad just the same way.
Please have a look at the attached schematic.
Best wishes from Germany
Jojo
Jojo
