pucho812
the last of the stumpers. The aux masters are still being sorted but at least there is something to go on.
The problem is with line inputs on a channel or two. They behave the same, if the line trim is at unity, and the output fader at unity on a channel I get intermittant signal. What I have noticed is it's dependent input signal level. So for example if it's working I can measure an input signal of +4dBu and measure the output of the channel at around +4dBu(within a decimal point) on the AP, this is with both input trim and output fader at unity. However if I lower the signal generator level, I can get it low enough too that the line input cuts out and this is with the input trims and output fader at unity. to get the channel back. to working, I have to adjust the signal generator, sometimes upwards at +20dBu in order for the channel line amp to come back on. thankfully I have a schematic for this but it is not a 100% match to the circuit board.
there have been a few other ways to get around this too, I can skip the line amp and go into the channel pre eq insert return and work. I can also reseat the channel strip in the frame and it causes signal to come back on and off.
I suspect this is cap or transistor related, but this is just a guess as I have yet to run the channel with the extender card.
