Inversing one channel in Power Amps
V9977
Athens, Greece
Would there be any advantage sound-wise in inversing the balanced input of one channel
of a power-amp and then connecting the speaker inversed to maintain phase with the other channel.
This would be for high-power PA applications.
Thanks.
I see the point - for common-mode signals the power supply load would be distributed evenly to both rails..
I like the idea, but I'm not sure of all it's implications
Jakob E.
Thanks.
A few amp makers have done this before. Carver may have been the first that I recall decades ago. It actually makes a few watts more power from a common power supply. Not audibly significant, but enough extra watts on paper to impress customers. One downside is speaker low/ground lead on one channel is now hot so you have to be careful about inadvertent grounding of that hot lead.  I actually encountered a customer with that problem from a snake that had speaker power leads built in. The sleeves of the speaker lines were grounded in the snake break out box. So the sleeve on a tip/sleeve speaker plug was hot and shorted out.
I used this in the amp section for a couple hundred watt powered mixer years ago, but for a different reason. Not for the few extra watts, but so I could easily offer a bridged mode output just by adding another output speaker jack.  So both amps could drive one speaker differentially (2x voltage, 4x power). I never used this in a normal amp.
