Analog_Fan
Hi there,
I'm looking at a wave rectifier circuit and i want the output inverted but not centered around GND, but to the power line.
that is when the outputted wave sits on the GND, the output should be the voltage of the power rail and follow the output of the opamp producing an inverted image.
I tried sticking on P/N-channel mosfets, all sorts of pnp/npn transistors configurations on the output of the opamp coupled to the power rail, using P type of devices distorted the output of the opamp, so i stuck on a voltage follower.
But somehow it doesn't or doesn't work to work.
How it's done?
How it's done?
