I have a used PT on the bench with a 6.3V CT filament winding.
When I measured DCR between each leg and CT I get normal (0.1r) readings. When measuring DCR across the full winding I almost invariably get 'open'. I did once manage to get a normal (0.2r) reading.
When running full AC into the primary I get 3.1V between each leg and CT and when I measure the full winding I've gotten 3 different voltages - 7.17V, 8.56V, and 9.07V. I suspected a loose connection but no amount of prodding and pulling affected the voltage readings - they stayed steady.
Yet the DCR is showing open . . . (except for the one time I got a normal reading)
I checked the winding with an AC Z meter and it reads way higher than I think it should. 186K vs 289r for each leg to CT indicating an open.
So, best I can tell there is something not quite right. Apparently a true physical open in the winding and I don't fully understand the situation of the AC getting through - induced where the insulation has broken down?
I plan on putting a string of tube loads on it later this afternoon and see what happens.
Any transformer veterans ever seen this before? I assume it's not a good idea to count on this winding still being reliable in circuit, or yes?
