Measure DCR of PRI wind taps, 120 tap should have more dcr by about 20 percent
So maybe you have a 5 ohm dcr on the 100 tap, 120 tap should read 6 ohms, you will need to compensate for lead resistance by touching leads and subtracting from measurement unless you have a dummy zero m
If it is a 240 tap nothing will pop, your tubes will barely light up, your plate voltage will be down, you will have low power and THC amp will sound like a big muff with a 3 volt battery, and this auto spell thing is driving me nuts, it put in THC instead of the The. Wtf?
