off with the head>
this thing is built, check the drive pins, what a pain,
i swear this stuff smells like plumbers putty,
Lams: 24-25 EL - 80 Ni with Insulaze coating, .014 thick, square stack, 1 x 1 ,
Pri: 403 T #36 green wire, L - 6.6 Henries D: 1.43 DCR-31 Ohms Start Pin 8 - Finish Pin 5
Cu Foil E Shield between pri and sec, soldered brn wire,
Sec: 8060 T #45 green wire, L- 2,400 Henries (est) D: .62 DCR - 2.8 K Ohms S - Pin 1 F -Pin 9
Turns Ratio - 1 : 20
Impedance Ratio; 1: 400
Input Impedance: 50 Ohms
Output Impedance: 20 K Ohms
