skipwave
Many thanks to @JLM Audio
I built this because I had the parts lying around. JLM’s GAIN PCB made it quicker and easier.
Input transformer is a random vintage with military code, I paralleled the secondary to use as a 1:7 turns ratio.
Output transformers
- Jensen jt-11-hfmpc (clean)
- Opamp Labs T-18 (dirty)
discrete opamp is the “Big FET Bloke”, a design born right here on this forum
The circuit I built matches the JLM Baby Animal, I just did it using the smaller JLM GAIN circuit board. The difference is that the Baby Animal PCB has the switches mounted to the front edge of the board and needs a deeper chassis.
Full circuit schematic: http://www.jlmaudio.com/BA/Baby Animal Ver2 Black PCB.pdf
Little power supply brick, if you want power inside the box:
JLM Audio Shop
Note: I have built Baby Animals with external power supplies, which you can get from JLM or find cheaper on eBay or Amazon
This is the little square “GAIN” PCB that I used:
JLM Audio Shop
Alternatively, this is the full featured Baby Animal preamp PCB that has the Phase / Pad / Phantom switches on the board:
JLM Audio Shop
If you can’t find a vintage input transformer, this one that JLM makes has the mojo:
JLM Audio Shop
Output transformers
JLM Audio Shop
JLM Audio Shop
JLM Audio Shop
JLM Audio Shop
