user 37518
Hey Guys!, just finished racking some MCI JH-500 modules i had available, i initially made this with the intention of selling them but after all the hard work i had to do, now im not sure..... but i want to hear the opinion of hardcore DIY'ers like you guys!
They are 2 MCI JH-500 rev D modules, racked in a 19" 3U custom made steel rack enclosure, it has a JLM audio power supply with custom made heatsink, plus an extra regulator board, it uses +/-32V for audio, +/-15v for diff amps (although they are now at +/-17V), 24V for LEDs and 48V phantom. I has both line and mic inputs with switchable phantom power, i added an LED at the top right to display phantom status, phantom is engaged/disengaged by pulling/pressing the gain knob. It has a switched pot at the top left, which is a Trim knob, located at the latest amp stage of the module, so the module can run hot and use that to lower the output so the DAW doesnt clip. EQ assign switch serves as a selector for Mic or Line input
The mic input has a Jensen input transformer, the line input is electronically balanced, output is transformer balanced, i included original MCI JH-500 output transformers i got from an MCI frame, all inputs and outputs are +4dBu balanced.
They have been fully recaped, all solder points have been resoldered, cleaned switches and pots, fixed every glitch, cleaned every knob.
Audio cable is Belden, power transformer is Hammond, it has double fused Bulgin AC inlet, Neutrik gold connectors.
The modules are originally 1 meter (40inches) long, so they had to be cut, the rack is powder coated steel, laser engraved. The whole thing weights around 12-15 Kilograms (25-32 pounds)
