Hi there,I built a pcb of the micro Km 84, but this one has a lot of background noise, can you help me to validate my circuit.
Have you put the circuit back in its metal casing or sleeve?the background noise is huge and continuous, but it still persists when the -6db pad is engaged. The pcb includes the reduction loop.
Hi there,
I have built that circuit a couple of times.
Got my PCB's from a fellow GDIY member here.
First describe the "background noise" so people here can help you.
Is it Hiss, is it Humm like 50/60Hz humm?
Is it frying or popcorn type noise (I'm not joking).
Try your best to describe what you hear or post some audio.
If you have not put the microphone sleeve back yet.
Could be that the circuit needs to be shielded (Faraday cage).
My 2 cents.
M
Did you thoroughly clean everything near the capsule connection? careful do not subject transformer to solvents.
Tantalum capacitors make the popcorn noise sometimes. Replace C3, C4 first?
I will try tomorrow, when the soldering of the wires is finished (22H in Canada), I maintain the wires with hot glue to the pcb, it prevents the wires from being cut, I use AGW22You have cleaned up the solder work? Take your time to flow plenty of solder, and be very still as it cools.
And then clean thoroughly.
Maybe post another photo of the micPCB enclosed in metal and an mp3 hosted offsite?
It's good to have Teflon standoffs at the junctions of R1-C9-C2-C1-Capsule and C1-G-R2."And the gate of the JFET and both 1G resistors seem to be connected through the PCB traces (as opposed to in-the-air or on Teflon isolation pins)."
