Hello,
New to the forum here. Would like to seek your kind help in troubleshooting a quirky problem with my Korg SDD-3000 Digital Delay (vintage rackmount).
Symptom:
- When dialing into a new program, the unit works fine
- When attempting in real-time to adjust the Direct/Effect (ie. wet/dry) balance by turning the "Effect" knob, the dry signal immediately cuts out regardless of which way I turn the knob. Only the wet delayed signal comes through. Setting at 100% dry yields no sound.
- Even though I can't hear the dry signal, by setting the "Effect" knob to any desired setting (ie. balance 50/50) and saving the preset, the saved preset -when retrieving it again by cycling the program button back to the preset- reflects the correct new post adjusted mix, so I do have a means of obtaining adjustment functionality after saving.
My guess is by turning the "Effect" knob, I am shorting out the dry signal in some way. Perhaps some failure on board "KLM-806", which is where the "Effect" control connects to. Below is a link to the service manual as well as owner's manual.
Service Manual: http://www.florian-anwander.de/korg_sdd3000/Korg_SDD-3000_ServiceManual.pdf
Owner's Manual: https://www.proun.net/blog/sdd3000_owners_manual.pdf
Any help would be greatly appreciated!
-Willshk
Symptom:
-Willshk
