raoul d.
Member
- Joined
- Oct 22, 2006
- Messages
- 7
I've been building two LA 2A drip version 1.
I finished them both and they both present the same troubles:
- They're buzzung a lot. Even if they're not switch on, when i plug one of them into my mixing board i have a buzz on my PA. But it doesn't get louder when increasing the volume.
- When i switch them on, the signal seems going into it well as the meter is moving accordingly to the signal. It just seems really sensitive: when the gain pot cross 4 or 5 the needle goes directly to the extrem right and stay stuck to it.
- And finally, the reduction pot seems doing nothing on the signal.
So my two LA 2A are having exactly the same troubles.
I used for both of them Sowter in and out transfos, and purusha cases.
One thing that i noticed (but i don't know if that could be a problem) is that my three 1 meg pots have a position at start where they clip and are totally off (sorry i don't know the english name for this kind of pot that could be switch off in a way). But i did my test with these pots on the midle of their run so that shouldn't change that much.
Thanks for those who'll help me. I know you have always lots of questions like that but i don't know who else to ask
EDIT: I used
- 45uf @ 450V for c7a and c7b
- 0,1uf @ 400V for c3
EDIT: I used
