LA-2A strange asymmetrical waveform
beatnik
Italy
Hi guys
I have just finished building an LA-2a point to point
The compressor works fine and sounds good
However I've noticed that the output waveform is clipped in a strange way. The top half is clipped, whereas transient can still be seen on the bottom half. I have attached an image of a drum track unprocessed (top) and then through the compressor.
I can't figure out if there is anything wrong because the compressor seems working fine actually
I hope someone can give advice if something wrong is happening
    156 KB
i think this is no error. try to lower the gain or use a preamp..
http://groupdiy.com/index.php?topic=19054.0
http://groupdiy.com/index.php?topic=11517.0
http://groupdiy.com/index.php?topic=48490.0
Stock LA2 has asymetrical clipping.
It's just that hot line amp.
Everybody overdrives it.
When you use the La2 with a mic pre, you can set up the gain correctly between devices.
Otherwise you need to pad a hot cd input, or turn the gain way down.
I did read those post while searching for possible problems
However, it seems a lot of difference between the two halves of the waveform
The top is chopped while the bottom still has a lot of transient movement
here is with the input signal turned down 10dB and the gain on the la2a at unity
    244.5 KB
here i turned up the gain from 50 (unity) to 60
    186 KB
i've also done some tests with sine waves at 100 an 1k Hz and confirmed that at unity the output has a symmetric waveform, if i go past unity gain it starts to become asymmetric.
Something was wrong actually.
I discovered very high voltages on V1 and V3 anodes. Around 200V for both.
I have replaced the tubes and now the compressor works better and the waveforms look fine
But I still have higher voltages compared to the schematic.
On V1 anode 160V instead of 130V and on V3 anode 130V instead of 100V
B+ voltage is 265V
Do you think they are fine ?
