I agree that 5V heaters are not any indication of a problem, unless you can definitively show a measured improvement with it raised to the typical 6-6.6V range.
I'd like someone also to measure the exact gain differences with tube type swaps. In practice I imagine 1-2 dB, again negligible.
As to practical reality, this is a repro of an american design from the time when all input was from low output dynamic mics. If you use a modern high output dynamic, or a condenser of any type, and are unhappy with headroom, you are really using the wrong mic for the system as designed. It does not imply there is a problem with the design, only the expectation.
