thermionic
- Joined
- Jun 3, 2004
- Messages
- 1,671
I made an LC EQ for a friend a couple of years back (designed by an esteemed designer at a firm I was involved with). He uses it live, in insane SPL situations. All was fine for the first year, but he's started getting hum pick up with it in recent weeks. However, this pick up seems to only occur in particular venues - noticeably ones in the US. I can't see why a venue in the US would be any worst than one here in the UK? Not all US venues are a problem - some are fine. I've had the EQ back here several times and, on each occasion, it's measured approx 110dB S/N ratio. I can't find a fault. It has a gnd lift switch, and bal / unbal toggles (it's transformer I/O) in case it has to interface with anything that isn't balanced (they simply short the cold leg to gnd - I've told him to experiment for least noise).
It's in a steel case and weighs a ton (literally). The trouble I have is not being able to mimick the situation in my workshop... Flying to the US, on the premise that it *might* hum, is an expensive undertaking. He's using it with a 120v-to-240v converter transformer.
He's also claiming that it has some microphonic-type behaviour. During heavy bass transients from other gear (i.e. no signal present) it hums, but is silent during less bass-heavy passages.
The only ideas I have at the moment are, to supplement the shielding with thick alloy, and replace input transformer (it's a 600r-600r which is unshielded - at line level, I can't see the shielding being an issue...?).
Many thanks in advance.
Justin
Justin
