druu
I'm currently designing a mono compressor using the THAT4305 IC and also utilising the THAT Corp bar-graph compression meter design note for this design (https://www.thatcorp.com/datashts/dn112.pdf). The meter functions fine except the last LED only lights very dimly for the -20dB indicator and I'm not sure why.
I'm basically using the values taken directly from the dn112 design note but have adjusted some values according to real world values I currently have on the 4305 circuit.
Here is a sim layout of what I'm currently using:
https://tinyurl.com/25w5544j
I'm not getting the same mV readings as the design note but I was wondering if the real world +/- values of my power supply may be a cause here? I have also tried adjusting to the 27k at the end of the resistor chain in the sim above to 10k so that mV readings are as per DN but all this does is only permit the meter range to be 6 LED instead of the desired 7 string.
Any suggestions appreciated.
