So I've been given a level devil to fix up. Compressor section was working but the expander wasn't. It still had a lot of original lytics in there and leaky caps in the signal path/control section. So I recapped the lot.
Here's the full schematic
http://www.harmonycentral.com/t5/Craig-Anderton-s-Sound-Studio/Gates-Level-Devil-Restoration-Blog/td-p/34460437
In the control section, the signal gets as far as the input to V6a, but nothing comes out of this diode. The heaters are working. Valve has been swapped. Valve socket tightened and cleaned. Voltages checked. Ground connection checked. R37/38/39 checked (all ok but replaced anyway just in case!) Still faulty though.
So I lifted C11 and R39 to isolate that stage as much as possible and it's just doing nothing. FFS!!!!
I'm stumped. Any ideas?
